โAug-15-2017 10:59 AM
โAug-18-2017 02:31 PM
soren wrote:I will tell you one thing for certain, I would never ridicule anyone on a forum simply because I did not agree with their opinion, esp. if I thought my opinion is superior because I happened to think I have more training, education, experience or qualifications. And I would never post any comments along with a note that I am a PE (ever...).
Electrical questions are always pretty entertaining on the forum, usually because there are plenty of wrong answers, but this one is in a league of it's own.
soren wrote:The OP's initial query is of a pretty basic & simple code nature. How are comments like the above and others you've made helpful in clarifying the OP's situation. I even commented that the OP could go to the Mike Holt electrical forum (where there are electricians, engineers, inspectors and other electrical experts) if he still had any doubts. How many homeowners even take out a permit to install an RV recept./pedestal? Not interested in debating the different methods for wire pulling and when to.
How many of you would expect to find pairs of massive feeder conductors, as in 3/4" diameter wires, bolted inside of a 50 Amp pedestal, with no breaker that size anywhere. How many understand a ten foot tap rule? RV park wiring has lots of things a typical residential electrician might find odd, or even wrong.
As I noted earlier, ALL of this depends on the local inspector, and they may be extremely competent, or clueless.
โAug-17-2017 06:40 PM
Bud
USAF Retired
Pace Arrow
โAug-17-2017 06:30 PM
stevenal wrote:
Breakers in the box make it a sub-panel. No need for a main breaker in the box for it to qualify as a sub-panel. Install a couple ground rods per code and you're good.
โAug-17-2017 08:21 AM
Kayteg1 wrote:Yes in my experience if you want a city inspection the city will require written drawings to review and a fee to be paid before the inspector comes out. And I think the OP will probably get perfectly good guidance if asking nicely at the city permit counter of the building code department.time2roll wrote:
You can have the city inspect your work if you have any concerns.
I am General Contractor and not expert in electrical, but did electrical in the past.
When I think your technical conclusion is correct, from the experience I can tell the City Inspector does not have to have electrical knowledge, although he might.
What inspectors do is checking out the build with the design, meaning you need to design and have it approved by Building Department for the inspection.
The Dept should have qualified planer who can elaborate on the design in their office.
Codes change from state to state and from city to city, so you can never tell....
โAug-17-2017 07:52 AM
โAug-17-2017 07:17 AM
Kayteg1 wrote:time2roll wrote:
Not an electrician but putting that combo TT-30 and 5-20 outlet should not be an issue using the existing 30 amp feed. Nothing wrong with multiple outlets on one branch circuit, the 5-20 has a 20a breaker to limit power so good to go IMO.
Of course it does become easier to draw more than 30 amps and still most sub-panels have more branch capacity than the main feed.
โAug-17-2017 06:29 AM
โAug-17-2017 05:48 AM
โAug-16-2017 06:36 AM
โAug-16-2017 06:14 AM
myredracer wrote:soren wrote:
What? I've pulled at least a million of feet of wire over thirty years as a licensed commercial/industrial electrician, I have never heard of, or seen, anybody who soldiered a head together, to pull wire. Got to give credit where it's due. Electrical questions are always pretty entertaining on the forum, usually because there are plenty of wrong answers, but this one is in a league of it's own.
Huh... As an EE, having worked with hundreds of elec. contractors over 30 years and having pulled many hundreds of feet of wire myself, guess I don't know what I'm talking about. Not the normal way of doing it, but for a homeowner who may not have the right tools and knowledge and for small wire, won't result in the pull cord separating from the wire being pulled in, esp. in a tough pull.
Have you otherwise got anything positive/helpful to add to the thread with all that knowledge as an electrician?
Guess not or it'd be above somewhere already :R
โAug-16-2017 05:51 AM
MrWizard wrote:
i have a near new fish tape
its only been used one time
in my past working lives, i have twisted, tied, taped, used wire cage pulls, and even steel cable come alongs or electric winches
i would solder them if i thought i needed it, to get them pulled, then cut off the end and finish the install
put discussing how to pull wire, that the OP does NOT need to pull
is not helping him
โAug-16-2017 05:41 AM
Dave H M wrote:
We coded and shmoded, and NEC and NEMA this one all the way to the ozone layer. :W
โAug-16-2017 05:32 AM
โAug-16-2017 05:12 AM
โAug-16-2017 04:55 AM
