Scissor Jack Bearings
buzzard616
Any body ever replace the thrust bearings on their leveling jacks. Where can I find the bearings for BAL 24000 series jacks?
Thanks
Stu
Stu & Jackie Metcalfe
2000 Salem 27FKSS
2008 Sierra 2500 HD gasser
2 REPLIES 2
j-d
Have you contacted BAL? I checked Amazon and their banded bearings "by INA" were as expensive as the ones linked at Grainger. Go to yard sales and look for scissor jacks? There are Scissors Jacks at Amazon that don't cost any more than the bearing! Unless the mfr cheaped out and didn't use a thrust bearing.
Terrydactile
You can buy them here Thrust bearings but they are not cheap. You can buy the whole jack for what these cost. Maybe you can find them cheaper somewhere else. They are called banded ball thrust bearings.
Scott & Theresa Boyd
2 Daughters (Cassie & Brittany)
1 Furkid (Ella, a Basset Golden mix)
2008 Keystone Passport 280BH
2013 F 150 Supercrew EcoBoost XLT
