Screws backing out
lenr
The screws in the trim strip at the top of the sides of our trailer are backing out. The strip covers the rubber roof where it wraps around the edge and reaches down the side about 2". I presume that these screws go into wood roof framing. Some screws are actually pushing the plastic covering strip out of place. I found about half of them stripped such that they're hardly holding themselves in. What material could I squirt into the holes before putting the screw back in that would help hold them in place?
19 REPLIES 19
Seon
3m 5200 and the screw will be in there forever.
monkey44
Nomad II
Nomad II
All three above ... stick glue and toothpicks, let dry completely. Then a slightly larger screw. Be careful the screw is one size fatter but not longer.
Another method. IF easy access, remove screw, drill slightly larger hole, then glue and punch in a hardwood dowel - a tight fit. Then drill pilot hole and a new screw.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
QCMan
Nomad III
Nomad III
And toothpicks!
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
capacitor
And a bit larger screw.
2oldman
glue
