Sealing Reefer Heating Area Floor
mrekim
I noticed this:
I'd like to seal that opening between the plastic trim and floor up. I know silicone is bad. What is the best option and why?
Thanks!
8 REPLIES 8
John_Wayne
How about a 4-5 inch wide piece Eternabond tape.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
bcbigfoot
BoonHauler wrote:
dougrainer wrote:
Why is silicone bad?????? That is what you DO use. Doug
X2 .....
Personally, I use Silkaflex 1A. It's pretty awesome stuff. I think it's a better adhesive than RTV.
Here's a link that I found. I buy it locally for 4.25 a tube in case lots.
Sikaflex 1A
X3 I like 1A as well but anything polyurethane will last 8 to 10 times longer than silicone.
2002 Dodge 3500 2wd dually, cummins, 4.10 gears, 10500gvwr, Rancho 9000's shocks
2005 Bigfoot 259.6E, 80watt solar, eu2000 Honda gen., 2x group 31 AGM bats., 7100 btu aircond, electric rear step.
dougrainer
mrekim wrote:
I seem to recall it being said over and over that there's no place for silicon anywhere on an RV.
I have some black RTV that I could use if that's the right stuff.
It seems like there should be something better. Something that will stick to itself so that if a re-seal needs to be done you don't need to remove the silicone from that fragile black "cloth" on the bottom of the compartment.
Where have you seen this????? I have been in the RV industry for 40 years, 36 as a tech and silicone is a perfectly good thing to use in the application the poster showed. If you look, it HAD silicone from the OEM at that spot. Silicone is NOT good on Styrofoam as it will eat it up. It will NOT work on rubber/epdm roofs. The thing I like to use is not Sikaflex(which is better than silicone), But a DAP product that comes in a red/white silicone tube. Lowes and HD both carry it. You can get it in clear and white. The neat thing about the clear is, it comes out white, but dries so clear you cannot tell it was even installed. It adheres to almost anything except rubber roofs. Doug
mrekim
I assume that either the wall or the floor is exposed under the repair area. I'm pretty sure there's styrofoam in both. It looks like the Proflex is not supposed to be used with styrofoam.
The Sikaflex has xylene in it, and I'm pretty sure that it does not play well with sytrofoam either.
Maybe I'm overly paranoid, but the I don't want to end up melting a hole under the area that I'm repairing.
I'm not sure about RTV and styrofoam, I'll have to look.
Another option would be to use a small strip of fiberglass cloth (I have some light stuff - 4-5oz or so) and a couple of coats of epoxy. This is assuming the epoxy doesn't melt the foam either. I've seen references where people use a foam core for epoxy projects, so I think styrofoam and epoxy play well together....
BoonHauler
X2 .....
Sikaflex 1A
05 RAM 3500 CTD 4x4 Q/C Laramie DRW/NV5600/3.73, B&W Gooseneck, MaxBrake, PacBrake PRXB, Brite Box Fogster, BD steering Box Brace
2014 BoonHauler 3614
Charlie_D_
Dicor or Proflex would be good choices. Although not a proponent of Silicone I would not be afraid to use it in that location.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
mrekim
dougrainer
