โAug-26-2013 04:31 PM
โAug-26-2013 10:16 PM
โAug-26-2013 08:38 PM
silverkid wrote:
Tanks for the replies. I'm thinking vent problem also - that I'll check on tomorrow.
I'm not ready for a '352' solution - it can't be for real.. can it??
โAug-26-2013 07:52 PM
โAug-26-2013 06:19 PM
louiskathy wrote:
I think it's a vent issue. You're dumping and that can cause the water in the "p" traps to be drained...allowing odors into your rig. More with the black tank than the gray I would guess. I put about 3" of water in the bathroom sink in our rig before we dump. That way, when we're done dumping, I just pull the stopper and put water back into the sink's drain.
I make sure I turn off all the ceiling vents but opening a bathroom window when you are putting a hose down the toilet to hose out the tank will bring up some bad odors.
Check under the kitchen sink - some rigs have a vent pipe there.
Check the vent on the roof, make sure that's not clogged.
That's about all the suggestions I can come up with from my experience and what I've read on this forum from others.
โAug-26-2013 06:00 PM
โAug-26-2013 05:58 PM
โAug-26-2013 05:35 PM
352 wrote:
Sometimes stuff gets stuck down there. Reach your arm down the hole as far as you can. When down to the max feel around for anything chunky. Grab it and squeeze it between your fingers until it gets smaller then dump some water in it (After you pull your arm out of coarse}. Do this once a month for regular maintenance. Wash your hands before cooking. I do have a self help video available. Hope this helps
โAug-26-2013 05:31 PM
โAug-26-2013 04:49 PM
