short in overhead lights, porch light & a.c.
tntluke
When I flip a light switch it is causing another light to go out and I try to turn on another light and the a.c. goes off. DC fuses check out ok. Battery is new.
7 REPLIES 7
Duck
Wire nuts are a source of a lot of electrical problems. Might check the wire nuts in the problem wiring circuit.
Don
08-FORD F350 PSD
13 Bighorn 3055RL {For Sale}
Bobbo
When strange things happen to multiple devices like that, I always first suspect a bad ground somewhere.
Bobbo and Lin
DrewE
I would suspect a bad ground connection, common to all the circuits in question. Finding the ground...that could be a challenge. Maybe the maker can supply you with a wiring diagram if you're fortunate.
MrWizard
Moderator
Moderator
normally what is called a 'short circuit' means a power path to ground and blown fuses
turning on a light and having the A/C shut off means a 'Voltage' problem on the circuit feeding the thermostat
could be the TS control power is coming off the same circuit as that light switch
how long have you had this RV, is this a NEW problem
check the batteries and the converter for loose or dirty connections
a recent purchase, that the previous owner updated with a newer A/C and TS
then something might be connected WRONG
I can explain it to you.
1997 F53 Bounder 36s
MEXICOWANDERER
Time for the digital multi-meter...
westend
You have a wiring issue. If I was to guess, one light switch is interrupting power from the thermostat. A further guess would be that some of the lights are interrupted by switches using the (-) phase of the 12 V wiring instead of the correct phasing, using the (+) phase.
'03 F-250 4x4 CC
1492
Moderator
Moderator
Moved from Forum Technical Support
