โJan-01-2022 07:04 AM
โJan-05-2022 06:09 AM
BFL13 wrote:
Surprisingly, Steve's above post has many errors wrt PWM and MPPT. It would be easier to delete it than try to correct it all. I am not feeling like trying to.
โJan-05-2022 06:08 AM
2oldman wrote:BFL13 wrote:He could use a good spell checker too.
Steve's above post has many errors...
โJan-05-2022 05:33 AM
โJan-04-2022 09:52 AM
โJan-04-2022 09:04 AM
โJan-03-2022 02:26 PM
Lwiddis wrote:
โThat seems like such a little amount. I thought it would be more about the solar's charging rates. Like "25amps per hour" or 25ah x 4.5hrs of sunlight = 100 amps charged in 'one day.' I havnt quite gotten to that research yet...โ
โJan-02-2022 05:01 PM
Rarely do 300 watt solar panels produce 300 watts. The sun must be directly overhead, the temperature must be moderate and very importantly the batteries must be willing to accept 300 watts. During bulk charging they may but during absorption they wonโt. The majority of the time recharging wet batteries are in the absorption phase. Lithium is different.
โJan-02-2022 05:58 AM
โJan-01-2022 10:22 PM
theoldwizard1 wrote:
For example, you want bacon and eggs with toast and coffee for breakfast. Easiest thing to use is an electric frying pan. Is you inverter up to the task of running the frying pan, toaster and coffee pot at the same time ? Throw in a hair dryer and few inverters could handle that.
โJan-01-2022 08:20 PM
โJan-01-2022 05:40 PM
โJan-01-2022 04:51 PM
โJan-01-2022 03:32 PM
Sarahps33 wrote:
Not sure what you mean by the 10:1 ratio. From what I've learned so far I've seen that different inverters draw different amount of amps depending on the wattage inverted.
Sarahps33 wrote:
Generators I've seen locally are pretty cheap, like $275 for 1500w. I'm thinking when its cloudy it may be worth having.
Sarahps33 wrote:
Thanks Piano, I didnt think about the leap the inverter would have to take from 12 as opposed to 48v. I would have liked to run a 12v system but I dont have but a month left before my lease is up. So maybe something for the future.
Sarahps33 wrote:
Laptop x2
Mp3player charger x2
E-cig charger x2
Phone charger x2
Flashlight charger
Coleman lantern charger
Mini dehumidifier 22.50w
Small fan
Overhead lights
Coffee maker 700w (10mins daily)
4.5 cubic foot fridge (not 12v)
Printer (100-200v/.6a)
Heating pad
And a couple other odds and ends
With that I ended up with 2510wh / 202ah
That's without the coleman mach 3 AC on top.
โJan-01-2022 03:04 PM
