Greetings,
Asking for a friend...he has a 2004 National Sea Breeze LX, model 8321, 32 ft. Class A. The bedroom slide is operated by an electric motor that has a shaft about 12'' long that goes to a square metal gear box. There is a spiral gear on the end of the shaft that connects to a regular tooth gear and drives the slide in and out. The motor is fine but both gears in the gearbox are stripped. He has been unable to locate a replacement anywhere and I wondered if anyone here on this forum had any suggestions.
