โJun-23-2015 10:17 AM
โJun-24-2015 08:21 PM
โJun-24-2015 07:26 PM
jwchenault wrote:I like the cordless drill clutch analogy - perfect! Wish I had thought of that!
KayDeeJay's description of the clutch mechanism in his unit sounds right to me and would produce the sound I was trying to describe.
โJun-24-2015 02:24 PM
โJun-24-2015 02:12 PM
โJun-24-2015 01:56 PM
โJun-24-2015 01:49 PM
wa8yxm wrote:Yes I do, three ball bearings sandwiched between two spring loaded two plates with ball detents on the motor drive shaft. The second plate drives the slide gears. When the load gets too high the balls overcome the sandwich spring pressure and ride out of the detent holes, allowing the motor to continue to turn while the output shaft is stopped. Makes quite a racket when that happens!
YOu have a clutch??????
โJun-24-2015 01:06 PM
โJun-24-2015 12:55 PM
โJun-24-2015 10:12 AM
โJun-23-2015 10:46 AM
Joe417 wrote:X2. Clutches ARE adjustable, but a PITA to do. Let the dealer take care of it for you.
It is not normal.
You should only have to touch the button. Get it corrected before warranty expires.
โJun-23-2015 10:39 AM
