Slideout acting up.....,
JK3045
2006 Winnie View..Just pulled in to a CG and when I extended the slide it worked but ran much slower than normal. Engine was running when extended. We did go thru a hellacios amount of rain today on the way here. Don't know if that had anything to do with it. Any ideas ?
2 REPLIES 2
is_it_friday_ye
I assume you checked to see that nothing fell behind the slide before you extended it? We've had a few things fall behind, like a tv remote, books etc...
2007 Dodge Ram 3500 Cummins SRW, Airlift airbags, Bilstein shocks, Smarty Jr., stainless turbo back exhaust, B&W Patriot 18K
2015 Grand Design Momentum 328M, disc brakes, Progressive Industries 50 amp EMS
sdianel_-acct_c
We don't have a View, but check wire connections to motor on slide. Ours was loose.
We also had loose wires in the electrical bay which caused intermittent slide problems.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
