Slideout won't close
lakeman48
I have a 2010 Freedom Express 242rbs. I am having trouble moving the slide in. Have to push from outside while activating switch , or it tries to operate but only moves a few inches. Once it gets going it goes by itself. When the slide is in its tight at the top and sticks out about 1 inch at the bottom (looking from outside). Only name can find is Happy Jack on slide activation switch. Inside looks like stove end of slide is dragging. Only adjustment I can find is under stove cabinet and 1 under the sofa.
6 REPLIES 6
lakeman48
Thanks again for the info. I will investigate further. There is a hard plastic sheet covering the bottom of the trailer and I can't see anything , looks like job to remove. The trailer has been sitting for a month w/slide out. After cycling in and out several times it seems to be working. It also seems to seal better now when closed. We are going to use trailer this weekend and will see how it goes.
BFL13
The Lippert electric slide has a "stop can" which can be adjusted in or out (threaded) If in the wrong position, this could stop the bottom of the slide from sealing all the way in.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Wheel_Estate
if it is all electric... mine has a gear box underneath that 'splits' with a drive bar to each side. mine did that when i sheared a bolt in one side of the drive. It took me a few trys (measure to the wall closely ) to get them timed again but it was not that hard.
Rick & MaryAnn
drive a Phaeton with
SMI brake stopping a Jeep toad
lakeman48
Thanks for the input! Am connected to Ac power. Batteries are hooked up and fully charged. Front of Sink Cabinet did hang-up on carpet when I put the slide out. I removed carpet when I tried to close. I did try to adjust the track brackets I found to raise inside of slide(1 under stove cab.+ 1 under sofa) a 1/4 inch. It seemed to help but power seems to shut off to slide motor(starts/Stops)Like a switch (pressure ?) stopping it. And once slide has moved 6 inches it goes ok.
Steeljag
Hanging up on carpet?
2018 Forester 3011DS
2010 Flagstaff 26RLS (Sold)
2012 Ford F-150 Screw Ecoboost H/D 3.73
1930 CCC
Going where the weather suits my clothes !
RoyB
On some of these slide setups it needs the extra power of the 12VDC Battery connected when being operated from Shore Power.
Might give that a try
just my thoughts
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
