Slider Windows
Kountryguy
I have a 99 Kountry Star fifth wheel with double pane slider windows. Some have become hard to slide. Can anyone suggest any possible remedies? I have cleaned the tracks the best I can and it made little difference. Thanks for any suggestions.
3 REPLIES 3
harold1946
Dry silicone works great. Any grease or oil will only collect dust.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
jmcgsd
Used lithium grease spray in my tracks.
'09 Pacific Coachworks Tango 276RBS
95 Lance 880 Truck Camper
'91 F350 Dually 2WD CC 7.5L (76K Original miles!)
AirLift Bags, Reese Titan hitch, Rancho 9000X
Ontarian
Spray some silicone lube into the channel, top and bottom, when the window is open. We also have double-pane sliders, and it worked for ours.
David and Denise, fulltiming since May 2011.
2011 Jayco Pinnacle 36RETS, Samsung RF197, 17.5 H-rated tires, Mor/Ryde wet bolts and X-Factor, Yamaha EF3000i.
2013 GMC 3500HD DRW 2wd D/A, Curt Q20, 46 gal aux tank.
