small elec/ceramic htr/solar?
blueh20
I am running 3 renolgy 100w eclipse panels on top of my 2014 ford e250 van with 40a commander and a 255ah lifeline battery.
Am wondering if a small elec/ceramic type htr would work for occasional use, take the chill out of the air in the van, maybe 15 minutes or so couple of times during the night in freezing temps ?
or is this too harsh of a drain on the battery?
really dont want to go propane if i dont have to.
I have a four led lights that draw 1amp
arb refer
usb charging port
and flowjet water pump pulls 7amps at full pressure, which is rarely used.
Is their a 12volt elec htr out their or is an inverter needed?
Any other options?
thanks for any input
23 REPLIES 23
MrWizard
Moderator
Moderator
Don't confuse peak draw and total draw
That mattress pad is not going to run at full draw continuously, unless you are sleeping on bare steel van floor
When on your bed aka mattress, it is going to draw what is need to keep the bed at the temp you set So it cycles on off,
our bed set over the engine, lots of cold air under there
we ran a mattress pad or electric blanket on the bed in the Safari, we had four batteries and a residential fridge, and no problems with overnight power, of course I'm not in the north east
Changed MHs , don't need the mattress heater so much now
I can explain it to you.
1997 F53 Bounder 36s
Jayco-noslide
Big power users- microwave, electric heaters, toaster and AC.
Jayco-noslide
theoldwizard1
time2roll wrote:
Overnight an electric mattress pad and a thicker blanket will give far more comfort.
While I agree that heated mattress pads do give nice warmth, better than an electric blanket, but a queen pad can draw 200 watts ! With a 90% efficient inverter and 8 hours you will need about 1800 watt-hours or energy. That should be about 150Ah on a 12V supply.
pianotuna
Nomad III
Nomad III
My 12 volt dc heating blanket works well. It draws 6 amps and does eventually start to cycle. I wish I could find a mattress pad as that would be even better.
If you wish to power a heater during "solar noon" you may run a 300 watt heater for about 90 minutes before and 90 minutes after. However, that may mean there is not enough sunlight left to return the AGM to fully charged.
If you had a firefly battery bank fully recharging needs not be done every day--but should be done once per month (or more often).
Has anyone simply connected their panels directly to a dc heater?
Regards, Don
shastagary
there is a 12v heated mattress pad i use that works well does draw 6 amp max when on but it cycles on and off so its not a continues draw.
electrowarmth
amazon price
wa8yxm
Ok, most of those small Ceramic heaters are dual wattage 750/1500
FOr ease of math divide by 10 volts. Power factor on these puppies approaches 1.0 (1.0 is by the way ideal) so we can forget power factor and just say 75 amps or 150 amps will be drawn off the batteries. Now the 255 amp hours you cited (What size battery is this or do you have multiple) is the 20 hour rate (or the wal_mart rate which is even worse) so at 150 amps.. I'd be surprised if the batteries lasted 5-10 minutes. at half power perhaps 10 minutes.. You need a LOT more battery and a LOT more solar to even think about it .
Not to mention more than one RVer had burned up his/her 120 volt wires using a space heater.
MEXICOWANDERER
Measured single mattress heating full size pad. Ninety+ watts. 50F night. Heat is on 5.4 out of 8 hours, using a comforter.
More than 40 amp hours...
This means a lot of fuel expended or an airfield landing strip's worth of solar panels in deep overcast winter usage. It was right after putting up with gen run time for a mattress pad that I purchased a Wave 8.
I remember 60 years ago my Aunt in Seattle explaining her electricity cost was less than 2 cents per kilowatt hour. It was so cheap her house was uninsulated.
time2roll
Hard to get electrical specs for mattress pads on-line. Browse Kohl's etc in person might be best. I recommend one with a brick that provides low voltage to the controller. They may all be this way now. Need the wattage rating to select an inverter. Need a small sine wave inverter to drive the pad. Maybe you already have one.
Yes I believe this will work for you.
TakingThe5th
SidecarFlip wrote:
GordonThree wrote:
Use the Sun itself to take the chill off, it's more efficient than converting the Sun's heat to electricity and then back into heat. move the panels out of the way, paint the roof flat black, insulate the windows, plug any outdoor air leaks, and park in the Sun.
Nothing like a sane answer to an insane question....lol
Make sure you turn on your headlights when you park in the sun at night, the sun is hard to see at that hour.
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
DrewE
A standard RV furnace does not add moisture to the inside air, since the combustion chamber is sealed from the inside air (and vents to and from the outside). An unvented heater will add moisture to the inside air, potentially quite a bit of moisture.
MEXICOWANDERER
If these heaters malfunctioned there would be a federal consumer protection safety alert, a freeze on the sale of the heaters, and lawsuits galore. Can't recall seeing a single issue EVER for millions of these heaters sold.
This model is tiny. Check out the dimensions.
IGNORE doom & gloom gossip. File it along with comets, asteroids, Nessie, Sasquatch, and "Honest Used Car Salesman".
Hundreds of people have used hundreds of CO detectors trying to get a alarm. Same for O2 shortage -- good luck. If you're worried and have 16 people on a sleepover crack a window. These heaters DO need a couple of feet clearance to the front and overhead.
2oldman
blueh20 wrote:
the elec mattress pad thats an idea, would one of those work with my setup or still too much of a draw?
Possible.
naturist
Short answer is no. Too much draw, not enough of either battery or solar panels.
SidecarFlip
time2roll wrote:
Overnight an electric mattress pad and a thicker blanket will give far more comfort. Electric space heater will drain the battery completely with little to no improvement.
Cuddling with your spouse works too....
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
