โAug-27-2014 08:10 AM
โSep-05-2014 04:48 AM
โSep-04-2014 02:32 PM
โSep-04-2014 02:30 PM
Almot wrote:wbwood wrote:
We won't use it very often with rv. And will want to use at home as I mentioned.
Do you homework, read up what was suggested on the 1st or 2nd page.
Doesn't matter where you will use it. See what Niner Bikes said about controller - it has to have the features that you need. Also, cable length and gauge. You are trying to get useful tips, but without understanding certain things you're shooting blanks.
If 100W is all that you are going to have, then cable gauge is less important (up to a certain length), but controller still needs to be a decent one. I personally wouldn't be able to do a lot with 100W panel, even with my minimalists setup. This is the problem with portables - a small one would harvest too little (almost nothing on a dark day), and a big array would be a tedious logistics of setting up and breaking down, especially if you move often.
โAug-29-2014 03:49 PM
โAug-29-2014 02:46 PM
smkettner wrote:wbwood wrote:Same thing RJ said a year ago. Then the setup/down logistics apparently became a bore.
Not mounting on top of the roof. Keeping it portable.
Not much to talk about connections with a portable... just slap it on.
I would get separate components over a kit.
โAug-29-2014 02:44 PM
โAug-29-2014 02:24 PM
โAug-29-2014 02:21 PM
wbwood wrote:
So the link I posted to the kit is decent?
โAug-29-2014 01:18 PM
โAug-29-2014 01:01 PM
โAug-29-2014 12:34 PM
wbwood wrote:SkiSmuggs wrote:
The 15' cable that comes with the Renogy portables is way too short so I plan to move the controller near the batteries. I really liked someone's idea of having two different length cables with quick connects. I had already replaced the alligator clips with ring/Anderson ends.
I'm debating on the portable or piecing it together. If I piece it together, I will go with some longer cable. The upside of going with the portables is that they will already be hinged together and have a built in stand. The downside is that the controller is mounted on it and thus you don't want to really have the panels too far from the batteries then.
โAug-29-2014 08:22 AM
My portable I mounted controller in a box and have a foot away from batteries. Use about 20 feet of cable between panel and controller.
โAug-29-2014 07:46 AM
โAug-29-2014 06:53 AM
