โSep-13-2013 04:47 PM
โSep-15-2013 02:55 PM
โSep-15-2013 02:54 PM
Rockinfigs wrote:This is flat wrong. Multiple sources of charging will not hurt the battery or any of the charging systems. Very common to have multiple systems charging an RV battery.
ok so from what i read i shouldnt use a solar panel charger/maintainer while iam using my hauler out in desert with the battery switch ON?
โSep-15-2013 01:30 PM
Rbertalotto wrote:
35 amp draw for static loads????
BTW...static loads are co2 detectors, propane detectors, etc. Stuff left on when you think everything is shut down.
โSep-15-2013 09:18 AM
RCtime wrote:
If you wish to understand the "why" surf here:
correctly interconnecting multiple twelve volt batteries
I rewired my 3 - 12V house batteries to the proper way. Winnebago had all the connections from the end + - battery posts on the slide out tray.
It took about 15 inches more wire. I guess saving a foot plus of wire for every coach they built with this battery arrangement was worth the savings to them.
โSep-15-2013 06:10 AM
โSep-15-2013 03:10 AM
โSep-14-2013 11:46 PM
โSep-14-2013 12:05 PM
โSep-14-2013 06:47 AM
pianotuna wrote:
This is what is balanced and best for twin twelve volt batteries.
As it often doesn't cost a dime more to do this, I think it is worth the trouble.
Others may say it doesn't matter--but unless there is a compelling reason to not optimize charging and discharging why not do it the best possible way?
โSep-14-2013 06:24 AM
โSep-14-2013 04:23 AM
โSep-14-2013 04:18 AM
Rbertalotto wrote:
Ok. Lots of confusing info here. 35 amp draw for static loads????
On that battery diagram. Am I missing something? How else would you hook up two batteries to still see 12v? Any other way and you'd see 24v.......
โSep-14-2013 02:07 AM
โSep-13-2013 10:08 PM
