โSep-21-2020 02:36 PM
โSep-22-2020 03:40 PM
ajriding wrote:
I would rather have 15 volts with a lot of amps, than 20 volts with a weak amp supply.
โSep-22-2020 01:19 PM
โSep-22-2020 09:07 AM
red31 wrote:Once the batteries are full the unused solar power is available for house loads, ie keep the batteries full until sunset. Some have used the excess power for say hot water but I'm not sure how well that works out.
For me the purpose of a controller is to limit power going to a battery (trailer storage), that and 'sleep' or night mode were it prevents batt drainage. 'Full by noon' means the controller was limiting power before noon and the rest of the day unless you have some other use of the excess power.
In active use many things limit power, location, calendar, orientation, temperature, overcast, smog, shade, bird poop, dirt ...
โSep-22-2020 08:51 AM
obiwancanoli wrote:
I'm still trying to wrap my head around the solar and power issue, but I have learned a lot. In conversation with my RV service tech, an independent guy who takes pride in his knowledge and work, I was listening to him discuss the wiring issue, in conjunction with a new Victron controller (100/50) and Victron 712 Voltmeter he'll be installing this week.
โSep-22-2020 07:05 AM
โSep-22-2020 06:03 AM
naturist wrote:Basically incorrect due to bypass diodes. Serial panels have better output than parallel panels with regard to shadows. Your 12V panels may not have bypass diodes.
Detail. Solar panels in series would charge longer during the day. Thatโs the good news. The bad news is that any part of any panel that is shaded will reduce the output of the whole array. When I bought my panels, I bought 12 volt panels, and because I have shading issues all the time here on the highly treed east coast, Iโve chosen to put half the panels in each of two series and then parallel the two halves. This to try and get the maximum output no matter what.
โSep-22-2020 05:31 AM
โSep-21-2020 05:45 PM
3 tons wrote:
Regardless of their source - the basics are that photons can excite electrons from the phosphorus doped side of a PV diode to jump the barrier gate to get to the boron doped side...e.g. my 440w panels begin to harvest at sunrise and 200a Li battery charging (beginning at about 60% SOC) is often complete before or shortly after noon time, this mostly due to the high receptivity rate of Li..
3 tons
โSep-21-2020 05:37 PM
โSep-21-2020 05:20 PM
โSep-21-2020 04:42 PM
bgum wrote:
Issue: can an artificial light cause a solar panel to create a charge? Yes
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โSep-21-2020 03:31 PM
โSep-21-2020 02:55 PM
