solar fuses
Muddydogs
What fuses are you guys using to connect you solar panels to controller and controller to battery's?
2015 Eclipse Iconic Toy Hauler made by Eclipse Manufacturing which is a pile of junk. If you want to know more just ask and I'll tell you about cracked frames, loose tin, walls falling off, bad holding tanks and very poor customer service.
39 REPLIES 39
pianotuna
Nomad III
Nomad III
Hi Twomed,
Yes, but how many watts?
Twomed wrote:
40a on the roof, disconnect box with 40a in 30a out after Tristar60
Fuses are cheap... fire is expensive, pretty simple. ??
Regards, Don
TechWriter
In my three 245W panel setup, I use MidNite Solar MNEPV breakers (not fuses):
2004 - 2010 Part Timer (35โ€™ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41โ€™ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31โ€™ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
2oldman
MEXICOWANDERER wrote:
What happens to an MPPT controller if the controller to panels conductors are shorted?
Shorted as in, "connected together?"
Fuses are not required for series PV installations, as mine is. Go ahead, tear me apart.
pianotuna
Nomad III
Nomad III
Hi Mex,
I'm at 256 watts so I did not feel I needed a fuse between the panels and the controller. I've not tried shorting it out. If I were at a higher wattage I would consider it prudent to fuse.
Shorting between controller and batteries without a fuse turns the wire into the fuse.
Just a question or two if I may...
What happens to the wires connecting the controller to the battery bank if it should develop a dead short?
Regards, Don
2oldman
Muddydogs wrote:
only fuses I have used are the ones that take auto spade fuses. Just not sure what to use for this application.
I doubt it makes any difference what kind, as long as the amp rating is appropriate.
MEXICOWANDERER
Muddydogs
From all I read the info say to fuse the hot line from the controller to battery as well as solar positive line.
I am looking for types of fuses as well, only fuses I have used are the ones that take auto spade fuses. Just not sure what to use for this application.
Twomed
Happy Trails ๐Ÿ™‚
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
pianotuna
Nomad III
Nomad III
Hi,
none between panels and controller
I do have switches to disconnect the batteries. They incorporate a 35 amp fuse.
Regards, Don
2oldman
none
