โSep-07-2014 10:43 AM
โSep-07-2014 12:39 PM
Twomed wrote:
40a on the roof, disconnect box with 40a in 30a out after Tristar60
Fuses are cheap... fire is expensive, pretty simple. ??
โSep-07-2014 12:08 PM
Muddydogs wrote:
What fuses are you guys using to connect you solar panels to controller and controller to battery's?
โSep-07-2014 11:45 AM
MEXICOWANDERER wrote:Shorted as in, "connected together?"
What happens to an MPPT controller if the controller to panels conductors are shorted?
โSep-07-2014 11:34 AM
Just a question or two if I may...
What happens to the wires connecting the controller to the battery bank if it should develop a dead short?
โSep-07-2014 11:15 AM
Muddydogs wrote:I doubt it makes any difference what kind, as long as the amp rating is appropriate.
only fuses I have used are the ones that take auto spade fuses. Just not sure what to use for this application.
โSep-07-2014 11:13 AM
โSep-07-2014 11:06 AM
โSep-07-2014 10:58 AM
โSep-07-2014 10:52 AM
โSep-07-2014 10:45 AM
