The volts should remain the same 21ish for all 12v panels. You may be confusing 24v panels with 12v panels. Note that Isc on 24v panels is half what it would be for equal wattage 12v panels (natch!
๐ )
You don't use PWM with 24v panels and a 12v battery system, you use MPPT (big bucks!) controllers with 24v panels to get 12v out to the batteries. Also the MPPT makes its own amps so the 24v panel amps specs mean absolutely nothing
You don't use Imp when on PWM. Use the Isc with 12v panels as expected max amps (except in edge of cloud effect when amps spike higher than Isc)
I have a pair of 100w 12v panels that get 6.3a each as Isc. Together (in parallel) they make 12.6a using the one PWM controller. If I had a single 12v 200w panel I would get the same 12.6a from the same controller.
So now you are asking, "How in heck can I figure out my expected max amps when using 24v panels where the amps spec means nothing and MPPT?"
We have reports that 235w 24v panel and MPPT gets 15amps pointed at the sun. This is about the same as you would get with 12v and PWM with 235w worth of panels. "How can that be when MPPT gets you way more amps than PWM?" you ask.
it seems that people might be seeing those half-amp specs on the 24v panel and seeing them double when using their MPPT controllers making 12v output and they think that MPPT is twice as good as PWM?
๐ who knows? ( I think MPPT is silly for the money it costs unless you have special circumstances, but never mind me!)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
