โJun-28-2015 10:13 AM
โJun-28-2015 06:16 PM
CA Traveler wrote:
OK, heat reduces the output but by how much? At 131F my panel specs say I should get 658W and I got 605W, so perhaps 53W was loss due to flat mounted? But my panels are mounted 6โ off of the roof so perhaps the panel cell temp is below 131F which is just a guess anyway.
We all use generalized panel information which is what weโve got and what I used as a basis for my system. But having a quality controller that logs data under live operating conditions is proving enlightening.
โJun-28-2015 05:44 PM
โJun-28-2015 05:30 PM
โJun-28-2015 05:16 PM
โJun-28-2015 11:35 AM
โJun-28-2015 10:49 AM
CA Traveler wrote:
How does solar illuminace effect panel output? From yesterdays observation at noonish:
750W, poly, flat, 100F ambient, Vmp=91.7V, Imp=8.18
Logged Varray=75V, Iarray=8.5A, Controller out=605W
Loads were greater than panel output so the controller was in max MPPT state. So it appears that the illuminace is keeping the voltage down but not restricting the amps???
BTW It was very hot all day so at 100F ambient those black panels had to rather hot. So why is the amp output greater than Imp? This raises a red flag for me about the discussions of significant reduction in amps when the panels are hot and PWM is better than MPPT? Wonder what my amps would have been at Jim's 11,000' playground?
No I'm not in denial about reduced amps at higher temperatures. But now wondering about all of the generalized comments about how much better PWM is vs MPPT when the panels are hot. Now wondering if this might be less general and apply to certain panels and/or controllers? There is nothing like having logged controller data to raise red flags.
โJun-28-2015 10:15 AM
