3x250W panels, 3 bypass diodes each, series connected 91Vmp. A 5-10A battery draw over the panel output was maintained until 2:08. The rig is in Casa Grande, AZ about 40 miles south of Phoenix and facing south on 3/5/15.
My interpretation of the graph and pictures. The tree shadows on the front 2 panels up to 12:48 caused their bypass diodes to conduct. The rear panel had full sun (see 7:30 picture) until 8:08 when there was a shadow on the leading edge (see 9:38 picture) causing one of itโs bypass diodes to conduct. At 10:08 the shadow was gone. The rising sun caused the rear panel to increase itโs amps and it peaked at 15A (see 10:30 picture).
At 12:58 the leaf shadows start to leave the front 2 panels and the effect of their bypass diodes is very evident. The voltage peak at 12:58 may have been due to wind. The voltage shows sun returning to one panel as the voltage reaches 60V as the bypass diodes are no longer needed and the amps continue to ramp up. This continues with the third panel up to 1:38. At 1:38 both the voltage and amps are at full output. At 1:38 and 85% SOC most of the house loads were removed and normal battery charging continued. The 2:18 transistion was likely normal house usage and the declining amps clearly show the battery SOC approaching full charge. The 2:18 voltage reduction is due to the MPPT reducing the charging amps.
At 12:58 the sun elevation was just pass itโs peak and changing slowly which combined with the 15 degree/hour azimuth change cleared the shadows from the front panels in about 30 minutes.
Whatโs your take on this data?
2014 Grand Cherokee Overland
Bob
