โMar-03-2015 10:40 AM
โMar-07-2015 01:38 PM
โMar-07-2015 11:05 AM
westernrvparkowner wrote:MWJones wrote:If you say so. However a concession trailer or a construction trailer or any other kind of commercial trailer is a lot different than an RV. There just isn't a whole lot of people looking for a used RV built by Tom, Dick or Harry. They shop manufacturers.
WESTERNRVPARKOWNER:
I don't know where you got your info about anything home built won't be worth anything. As posted earlier, I built a 24x8 concession trailer. I used it for 12 years and sold it for 2 and 1/5 times what it cost to build. If built well and kept well it WILL be worth something.
Rally's attended so far-21
โMar-07-2015 10:42 AM
john&bet wrote:Mr_Steve wrote:I would suggest you make a visit to your local electrical wholesale house. Explain to them what you would like to do. They will help you out. At least the ones around here do.
Currently in the process of selecting my panel. Seems like this should be easy. Would be nice to have 10 circuits even though that's overkill. Here is one option I found but can't find many others. Anyone have other panel suggestions?
http://www.northerntool.com/shop/tools/product_200196374_200196374?cm_mmc=Google-pla-_-Generators-_-...
โMar-07-2015 10:24 AM
โMar-07-2015 10:12 AM
โMar-07-2015 09:47 AM
Bud
USAF Retired
Pace Arrow
โMar-07-2015 09:28 AM
โMar-05-2015 10:38 AM
โMar-05-2015 10:30 AM
โMar-05-2015 09:22 AM
โMar-05-2015 09:06 AM
greenrvgreen wrote:
The OP says he isn't concerned about resale value, and yet he keeps coming back to resale value. If the OP is assuming that the Gold Rush economics of the ND Oil Patch will still be in place when he tries to sell his trailer eight years from now, he should study up on supply and demand.
As far as towing a 15,000-lb (dry) trailer with a 1-ton, I would leave that up to the towing experts. But I would at least urge the OP to try towing SOMETHING before he tries towing something that heavy.
Or consider having a professional trucker move it for him, the few times he's going to move it. But then he has to reason why he doesn't just buy a bunch of park models and park them places, as was suggested previously. Personally, the more I realize I hate towing the better that idea looks to me.
As far as the OP's original question about electricity (where he mentioned resale value twice), I would agree that 50a should be considered the minimum for a rig that's mostly going to sit.
โMar-05-2015 08:12 AM
โMar-05-2015 07:11 AM
Rick Jay wrote:
OP,
Building on greenrvgreen's comments above, I think a realistic assessment should be done on it's expected value if you have to sell. I believe you mentioned that you'll be in Washington for a few years, then possibly move up to Alaska.
Have you considered just getting a used park model for now, selling it when you need to move, and then when you have a better idea of where you'll be permanently located, buy something there? I know it won't be quite the layout you want, but it will get you housing cheaper and probably be easier to sell as well. This will only be "short term".
I think this is a neat project, but I'm not sold on the idea this will have much value to most people, may not be allowed in some campgrounds and wonder what it might cost you to have it towed from Washington to Alaska if you don't have access to a very large truck.
Now if you're building it and don't expect to sell it and have the means to safely move it, that would be different.
Again, good luck. I hope it all works out for you. ๐
~Rick
โMar-05-2015 06:57 AM
MEXICOWANDERER wrote:
A couple of points if I may...
RV Park 50-amp receptacles tend to be in better shape than 30-amp receptacles. You will be drawing a lot less.
Wire L2 to all the items that you would never wish to run while boondocking.
For Alaska I would be sorely tempted to fit healthy size home baseboard heaters in the living room and bedroom. Thermostats.
Plenty of receptacles. Spec grade and 12/2 marine duplex - tinned.
Marine not RV switch type breakers on both AC and DC. Klixon just like on a sailboat. Smaller, neater, easier to wire and a lot more durable.
Order lots of 10-12 gauge uninsulated fork (spade) terminals for receptacles. Much better contact and WAY easier to wire.
Rerurning to your power panel...
Klixon ganged 40-amp master breaker. A pair of inexpensive 200-volt digital AC voltmeters. Plug in, refer to the monitor and when YOU decide that L1 and L2 are adequate YOU flip the ganged Klixon and power-up. This guarantees zero missing neutral nightmares. You can also monitor each AC leg at the same time.
Wire the rig with intelligent wiring color coding. Black Blue white and green for the 240 AC.
Red and YELLOW for DC. Yellow is now the standard YSB color coding for 12-volt ground. It prevents fatal confusion between 120 volt hot legs and DC ground.
Use 16-gauge duplex wire with yellow ground for 12-volt lighting feeders. Instantaneous recognition of circuit.
I did all this with the 2 buses I built. But it was a long time ago. Analog gauges, halogen lighting and BW Magnatek chargers. Yes all this costs more. But you will throw yourself kisses in the mirror later on.
Forget resale value. You are building a heirloom. A new 40 grand rig is worth 30 the instant it hits the street. If you hide an 8,000 BTU window AC under the bed and a second AC under the dinette seat you will jump for joy at the elimimation of problems using AC with a generator. I refused to endanger an AC by placing it on the roof. One tree limb and ka-pow. Also leaves the roof wide open for solar panels.
Good fortune to you! Planning and building your own rig to me is fun beyond description.
One more note - insulate the heck out of the gas refrigerator insert space. I used 4" rigid foam block. Then foam insulated the actual rear of the refrigerator. Saves EIGHTY-PERCENT on LPG. I clad both doors in 1" foam board with mahogany panel (thin).
