โApr-19-2016 05:20 AM
โApr-19-2016 01:13 PM
beemerphile1 wrote:
The statement was made that a system with panels in series could be dragged down by a poorly functioning panel. A system with panels in parallel would not be affected by a poorly functioning panel.
โApr-19-2016 11:43 AM
teeznu wrote:
So the debate between wiring panels in Series or Parallel. Please tell me the benefits of wiring either way
โApr-19-2016 11:36 AM
beemerphile1 wrote:
Saw a tv show about solar on houses and other buildings. The statement was made that a system with panels in series could be dragged down by a poorly functioning panel. A system with panels in parallel would not be affected by a poorly functioning panel.
Others may be able to explain the hows and whys of the statement.
โApr-19-2016 11:29 AM
โApr-19-2016 10:56 AM
โApr-19-2016 10:31 AM
โApr-19-2016 10:05 AM
โApr-19-2016 09:54 AM
โApr-19-2016 09:14 AM
โApr-19-2016 08:39 AM
โApr-19-2016 07:52 AM
hypoxia wrote:
Series provides a higher voltage which allows the use of smaller wiring to the controller. If wire size is not a factor then parallel is best.
โApr-19-2016 07:46 AM
โApr-19-2016 07:41 AM
โApr-19-2016 07:32 AM
โApr-19-2016 07:29 AM
