Jan-26-2020 04:27 PM
Jan-27-2020 04:30 PM
Jan-27-2020 02:24 PM
Jan-27-2020 06:38 AM
dougrainer wrote:tallpall888 wrote:
True...and we have had no problem with lack of hot water with this 10 gallon unit. There *is* a problem with the safety valve blowing occasionally and this is the second valve for that heater so the thinking is there is a problem with the thermostat letting the water heat too much. Replacing with even the standard temp sensor might have helped, but I don't anticipate the 130 degree unit I just ordered ($10 ebay) will be noticed.
The Pop OFF valve RARELY fails. What you have is a diminished AIR POCKET
in your Atwood tank. Doug
PRESSURE-TEMPERATURE RELIEF VALVE Weeping or dripping of a pressure-temperature relief valve while the water heater is running DOES NOT mean it is defective. This is normal expansion of water as it is heated in the closed water system of a recreation vehicle. The Atwood water heater tank is designed with an internal air gap at the top of the tank to reduce the possibility of weeping and dripping. In time, the expanding water will absorb this air. To replace the air follow these steps: Step 1: Turn off water heater Step 2: Turn off incoming water supply Step 3: Open the closest hot water faucet in the coach Step 4: Pull handle of pressure-temperature relief valve straight out and allow water to flow until it stops. Step 5: Allow pressure-temperature relief valve to snap shut, turn on water supply and close faucet.
Amateur Radio K3EXU
Jan-27-2020 06:15 AM
Jan-27-2020 04:19 AM
Jan-27-2020 04:14 AM
Jan-27-2020 04:10 AM
ggardne2 wrote:
Just for info most Atwood/Dometic water heaters have a front mounted thermostat that controls the 12V propane circuit and on the back of the heater there is a second thermostat that controls the 110V element. If you only change the front thermostat it will impact the propane temperature but will have no impact on the electric element temperature. Unless you have a rear access panel or access to the back of your water heater you will need to remove the water heater to access the thermostat for the electric element (at least on any Atwood I have experience with). You can verify this information by reviewing the wire diagrams in the manual to your water heater.
Jan-26-2020 07:33 PM
Jan-26-2020 06:51 PM
Jan-26-2020 06:48 PM
Jan-26-2020 05:55 PM
Jan-26-2020 05:26 PM
Jan-26-2020 05:10 PM
Jan-26-2020 04:56 PM
