โNov-10-2016 01:04 AM
โNov-11-2016 04:48 PM
MrWizard wrote:
The answer.. Not full because it never got to the proper voltage
It is/was near full , but not full until topped charged at the correct voltage
โNov-11-2016 04:30 PM
MrWizard wrote:
You will be find
That's a good way to do it
Your question was why isn't it full if it stopped taking amps when driving
โNov-11-2016 04:04 PM
โNov-11-2016 02:52 PM
MrWizard wrote:
its simple look at the charge voltage for your AGM 14.6 > 14.8v
that is the voltage needed for full charge 13.6 > 13.8 is the float voltage not the charging voltage
โNov-11-2016 12:58 PM
โNov-11-2016 11:15 AM
โNov-11-2016 10:53 AM
pnichols wrote:and that would normally indicate full batteries. But I have no idea what kind of charge controller a vehicle has - to know if there's still an absorb phase left to do.
.. no one can fully explain what I'm seeing...After 3-5 hours of driving between campsites, it usually is showing zero amps flowing. ...
โNov-11-2016 10:45 AM
โNov-11-2016 09:46 AM
2oldman wrote:
It takes considerable time to bring LA batteries up to 100% charge. I'm not sure how much you use your batteries, or if they are actually fully charged.
โNov-11-2016 09:30 AM
allen8106 wrote:
For what it's worth I am installing a solar system on my 5ver at about $1,811 in cost.
4 - 130 watt panels used from Craigslist. ($65 ea., total $260)
2 - Crown 240 ah 6v batteries ($135 ea., total $270)
1 - Magnum Energy MMS1012 inverter ($737)
1 - Morningstar TS-45 Charge Controller ($143)
1 - Bogart Engineering TM-2030-RV Battery Monitor ($158)
1 - Morningstar battery temp sensor ($25)
1 - Magnum Energy inverter remote ($47)
1 - GE 60 amp disconnect w/fuses ($21)
1 - Generac 60 amp manual transfer switch ($100)
1 - 500amp shunt ($34)
1 - 200 amp DC fuse ($16)
So far I have installed the batteries and the battery monitor. I have purchased everything else and am just formulating my install plan and panel locations. I am fabricating my own panel mounts, I have developed my own wiring schematic and am doing all the install myself.
I expect to be able to run everything except the microwave and the AC without ever running a generator or being hooked up to shore power, my wife also uses a CPAP.
So why all this. To show you that a good solar system install can be done for considerably less than you think and to let you know that what you wish to run in your rig can be done within reason. You'll never run the AC on solar and you'll not likely run the microwave unless you have a really big battery bank and inverter but should be able to run everything else.
โNov-11-2016 09:27 AM
pnichols wrote:It takes considerable time to bring LA batteries up to 100% charge. I'm not sure how much you use your batteries, or if they are actually fully charged.
Our motorhome's 130 amp Ford engine alternator completely charges our RV's battery bank with only 3-5 hours of driving between destinations. How can an engine alternator charge better than a good multi-stage battery charger?
โNov-11-2016 09:24 AM
BFL13 wrote:
I got solar, not to avoid using the generator so much, but because I could not get the batteries full enough with the generator in a reasonably short generator running time.
โNov-11-2016 08:04 AM
2oldman wrote:Yeah, what is the fuel cost for those that run the generator? An added battery or two would eliminate the fuel costs and could be charged the following day when noise wouldn't be as troublesome. My little solar system will run the screen, a stereo receiver, a disc player, a small fridge, and typical 12V loads for days as long as the sun shines.MrWizard wrote:I'm always amazed at the number of Quartzsite campers who run a generator to watch tv.
You can have a big inverter to power the MW at night then recharge with a generator during the day
โNov-11-2016 07:09 AM
โNov-11-2016 07:08 AM
