โOct-09-2013 04:35 AM
โOct-13-2013 02:15 PM
โOct-13-2013 10:13 AM
MrWizard wrote:For enforcement rule of thumb for us Statey guys, if an item extends past the farthest most portion of an OEM mirror, then it is citable. (After market or extensions won't cut it, so don't even suggest it) Also, if an item is deemed (the opinion of the officer, as presented in court)to be dangerous to the motoring public, it is citable. Example recently, two kayaks attached to the side of a truck camper going down the road of a narrow two lane highway.
DOT legal limit in the USA is 'BODY' 102"
mirrors and awnings, do NOT factor into the DOT width limit
as they are 'addon & removable'
โOct-12-2013 04:22 AM
โOct-11-2013 09:37 PM
โOct-11-2013 06:33 PM
buta4 wrote:
Greetings .. as an FYI ... a university (name escapes me) has invented a SPRAY ON photovoltaic membrane onto any surface, even FLEXIBLE surfaces.
PRO:
Imagine your awnings coated with this film. Humungous area for generating electricity.
CON:
Still in development phase and voltage output is still low at this point.
Don't hold your breath though and go with your ideas that you have now.
Regards,
Ray
๐
โOct-11-2013 09:44 AM
pianotuna wrote:
Hi,
I've moved to being full time in the RV.
I'm in the first stages of planning a solar "wing" for the driver's side of my RV. I want to hinge at the top so I can tilt when stopped.
I'm open to all ideas about doing this. I will probably use MPPT with the panels in series.
I'm 100 inches wide so I want to keep it "thin".
I'll have to avoid the furnace/water heater so there will be a gap.
The panels will double as awnings for the bedroom and dinette windows.
โOct-11-2013 08:18 AM
โOct-10-2013 03:43 PM
โOct-10-2013 08:40 AM
โOct-10-2013 06:36 AM
โOct-09-2013 03:50 PM
JiminDenver wrote:
Is the heat from the panels a concern? I notice Tom has his a bit off the body with the way he mounted them.
I was also wondering about the heat on the window seals.
โOct-09-2013 03:10 PM
pianotuna wrote:
Hi Jim,
Ummm the seals should be cooler than they would be in direct sunlight? Am I missing something? (easy for me to do)
โOct-09-2013 02:36 PM
โOct-09-2013 02:35 PM
JiminDenver wrote:
Don
