Splendide Washer/Dryer
09FLSTC
Worked great. Now slow to dry. Always really was but now it barely gets hot. Vent cleaned and ruled out. Wondering about control board.
9 REPLIES 9
09FLSTC
Great stuff. Thanks!
Scottiemom
When mine would not heat, it was the control board. It would tumble and do everything correctly, but not heat.
That was a few years ago, now it has a new problem. It won't spin. Goes through all the cycles, but won't spin. Sure it's the belt. Waiting to get back to northern Indiana and take it to the service center.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
Traveling with Brendon, my Scottish Terrier
2022 Honda Odyssey
2011 Mazda Miata MX-5
2021 Coach House Platinum III 250DT
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
YC_1
double posted
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
YC_1
I did not write this but have saved it to share.
Procedures for cleaning out the lint from the washer/dryer:
"they eliminated the lint screen in the 2100 with a design feature that catches the lint in water and flushes it down the drain. Nice idea, but not quite perfect in results."
THE PROBLEM: With use the lint eventually sticks inside and restricts, then plugs the air outlet, making the dryer useless." If you have a lint screen, you should be OK. If not, you might want to try the process. For the 2100XC, cycle 11 is "silk", which adds A LOT of water to the drum. Cycle 2 is "heavy duty". You'd have to check for comparable cycles on an older unit.
Clearing lint from Splendideโ€™s Interior Duct
1. Run the unit without clothes and with the dry time off on cycle # 11.
2. When the water stops entering the unit push and hold the start button until all the lights come on then release the button.
3. Next, move the cycle knob to cycle # 2 and press the start button once (do not hold).
4. Let it run through that complete cycle.
5. Do this twice.
If in frequent use, do this once each month to avoid buildup.
If the above treatment fails, try it again, adding a cup of white vinegar to break down the deposited soap and fabric softener.
FALL BACK PROCEDURE IF THE ABOVE PROCEDURE FAILS
1. Pull the unit out and remove flexible exhaust duct.
2. Pick out as much lint as you can from the air outlet on the back of the dryer.
3. Put a garden hose in the outlet and blow the blockage into the washer.
4. Run the washer on a short cycle. The blockage breaks up and goes out the drain.
H/R Endeavor 2008
Hoosier_Cruiser
Also, clean the filter. I found a coin that was preventing the little fan from turning.
Hoosier Cruiser
09FLSTC
I was wondering that exact thing Vance. I'm going to pull it and check that. I went from the outside and its true you can't really turn the corner that well. Thanks.
vance
I did read that you cleaned the vent, so the may be something that you have already done. I had to remove the back cover, go in and remove the rubber extension between the washer/dryer and the outside vent to find that lint had built up enough that the 4inch hole was no longer open enough to stick my finger in. Once I cleaned that, the dryer worked great.
vance
2007 Coachman Encore
330 HP Mercedes
Honda CRV toad
"If you see our children, PLEASE don't tell them where we are"
09FLSTC
Will do, would think no heat at all if it were the heating element. Not familiar with this brand but will get on it.
donn0128
Check the heating element. Pretty simple to access once you pop the top off. Dont forget the two screws in the back.
