Stabil or Seafoam for long term gas can storage?
profdant139
First, I can't believe that this is the first time this question has been posed, but my search of the archives came up empty?!
Anyway, which of these two products (Sta-bil or Seafoam) is better for storing gas for a long time in a can? And how long is too long?
Thanks in advance!
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
69 REPLIES 69
suprz
mchero wrote:
I see a product up here called TrueFuel. Ethanol free. Also sells a 2 stroke fuel. Never used it but seriously considering.
I use that in my 2 stroke weed whacker all I ever do with that is run the carb dry and put it away in the winter. Never have a problem with it in the spring. Everything else gets seafoam. Trufuel is non ethanol.
Other than give cars worse gas mileage (which would negate the so called "clean air" aspect of running ethanol in your engine, and making the manufacturer's of carb cleaning products very rich, the fed subsidies for farmers... ethanol is the devil for gasoline burning engines. My own opinion is that seeing how much farmers need subsidies from producing ethanol corn, it is a ingrained business that can't go away without killing a large portion of the farming economy. but that's just my opinion
Proud father of a US Marine
js218
^^^^^^ Sunoco 93 octane contains 10% ethanol, thats my reason for adding red Stabil to all my equipment.
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
JimK-NY
I live in NY and have never seen non-ethanol fuel for sale. It is a shame because it seems to be mostly just a subsidy for the ag industry without any positive environmental impact.
Dave_H_M
A long time ago, seems like on here, someone posted a home grown version of Sta Bil gleaned from the ingredients from the MSDS sheet. It works for me but there is no additive specified for the Aromatic ingredient. :W
B_O__Plenty
Non-oxy fuel and I use nothing in it while I store my lawn equipment over the Winter months. Never a problem.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
mchero
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
Boomerweps
Nobody's seen Pri-G?
There's also a Pri-D for diesel.
Supposed to stabilize fuel for several YEARS. It's the prepping websites and post apocalyptic stories' darling. Can usually be found at marinas or mail order. It supposed to even rejuvenate (or at least make useable gas & diesel that has been sitting for a while.
So far the Pri-G works in the stuff I've put it in.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, ITBC, SumoSprings,
Gjac
To answer your question directly I prefer Seafoam over Stabil because it does two functions, stabilizes the gas and cleans the fuel system. In practice I don't add anything to my gas for winter storage. I run the genset several times under load during the winter anyways so I don't drain the carburetor. I use the Seafoam in the spring in a gallon gas tank and run the genset to clean the carburator. Every other year or so I will pour Seafoam down the TBI of the 454 engine and clean it out along with the tow car and add Seafoam to the lawnmower tank to clean it out. I also use it in the crankcase of both engines and am amazed at the carbon buildup that comes out when I drain the oil. Lately I have been using Berryman's B-12 also, it works also and is cheaper. As far as how long is too long if I were going to store gas for two or more years I would use Stabil less Seafoam.
I use good ole fashion non ethanol ( cheapest rating I can get ) in all my stuff sitting in the shed... IF it starts to show signs of rough running, I toss in some Seafoam..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
ksg5000
I use Seafoam in my mowers/chippers etc. Nothing in my RV/cars and nothing in the 30 gallons of emergency gas I keep on hand (which gets cycled out a couple times a year).
Kevin
Bumpyroad
I forgot to mention, nothing but ethanol free gas in my stuff.
bumpy
wopachop
Doesnt supreme gas lose octane as it sits? The 91 you bought a year ago might be 87 octane by the time you use it.
Star Tron cleans the carb and removes water. Its not just about the ethanol getting gummy.
js218
^^^^ some of my equipment sits for 12 - 18 months depending were I'm at in my travels currently in Northern Vt. heading to north central Pa on Monday for a couple weeks then on to Lake Tahoe for a week then down to Baja Sur Baja Mexico.
Jim
Cummins12V98
Not sure why you would add anything to non ethanol gas??? 87 gallons in my GlasPly Boat at the end of the season. Fires right up in the spring and runs great.
Really not sure why someone would run Supreme in EVERYTHING when it clearly is a waste of money in things that don't require it.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
js218
Nothing but red Stabil and 93 octane gas use it it in 4 snowmobiles, 4 atv's, lawnmowers and snowerblowers, Kubota tractors get winter additives added.
Jim
