storing the MH in winter
anon125
we live in the north west. winters are usually mild but wet.
last winter was the first time we had needed the drying crystals routine.
this winter the MH probably will be in a metal barn.
doubt it is heated or insulated.
do we still close all vents and use the crystals?
thanks all
2006 Itasca sunova 29r
6 REPLIES 6
anon125
thanks
we always stored it outside without crystals.
but last year was awfully wet!
CarnationSailor
I live in the NW also and store our trailer outside. Instead of closing vents and using crystals, I crack open the vents and crack open a couple of windows, and use NO crystals. Has worked great for the past 7 years.
And I would use the same method if it were stored indoors.
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
anon125
thanks
but do i still use the crystals and close the vents when it is in a shed?
midnightsadie
I use peppermint oil and fresh cab, no mice in my rv,s or my boats, renew the peppermint oil couple times a winter if you can, or just put some in a little dish, I sprinkle mine threw out the rv, even top of tires.and there stored in a pole bldg in the country.
anon125
good idea!
midnightsadie
mouse proof it.
