strange axle nut on 5th wheel hub
Milehunter
Hello all, first time poster.
I have a 2010 28RKBS Wildcat that I am trying to repack the wheel bearings on and ran into a problem. It has what looks like a large nylon locknut
with no normal castle nut and retainer. Also inside there looks to be a snap ring. has anyone else ever seen this used? Any help would be appreciated. thank you.
11 REPLIES 11
Veebyes
Nev-R-Lube bearings here. 10 years & what must be over 100,000 miles on them.
Every year each wheel is lifted for one reason or another plus given an attempted shake, a spin & a listen for bearing wear. At every highway potti break each wheel is given the touch test for abnormal heat looking for a first sign of bearing problems or brake drag. A good habit to get into.
So far, so good.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
Lynnmor
BB_TX wrote:
Nev-R-Lube™ Drums/Bearings
Notice how the two bearings are right next to each other, unlike the usual design with bearings being some distance apart. Now picture picking up barbells with your hands next to each other and then again with your hands spread apart. I call it a very poor design.
Slownsy
If Newer lube by Dexter it is not a plastic nut and it has to be torked to 150 lb, Dexter gives specs for hove much play are allowed in them and there are different sizes so find out what you got and go to ther website or contact them for specs.
Frank
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
RAS43
I have Nev-r-lube bearings on my 5th wheel. It is 16 years old and I replaced the bearings at 10 years. They felt okay but the seals were leaking a little. The new bearings were pricy- over $100 each and I had to have a machine shop press the bearings out & in. I check for end play and noise each spring and about every third year I pull the hub and examine the brakes. I reuse the lock nut which has to be torqued to specs. Personally I like them, less messing around with grease, IMO.
bobsallyh
Yes, it is a probably a Never Lube by Dexter. When they let go, "Katie bar the doors". Just another sales piece of BS. Like you, just give me the standard bearing. Usually when the Never Lube goes bonkers, just plan on buying a whole new unit. I haven't "been there" but helped a friend that was "there".
BB_TX
Milehunter
Thank you all for the help. It would sure be a lot easier if they where standard hubs. When I pull the hubs off to inspect the brakes, can you reuse the locknut? Maybe someone has some tips. Thanks
Lynnmor
drsteve wrote:
In a car or truck, when a bearing begins to fail you can hear it and often feel it. So how does one tell if a never lube trailer bearing goes bad?
You see smoke and flying parts in the mirror.
drsteve
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
BurbMan
A photo would help
corvettekent
It sounds like a Nev R Lube bearing, so it's sealed and you can't repack it. They are good for 100,000 miles.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
