โAug-08-2014 06:56 PM
โAug-11-2014 02:06 PM
โAug-11-2014 01:09 PM
โAug-10-2014 10:46 AM
โAug-10-2014 08:05 AM
smkettner wrote:
With the above transfer switch only the fridge will see inverter power. The rest of the RV is isolated from the inverter. There will be no effect on the Progressive Dynamics power management system. All systems remain protected and isolated if you have the inverter on at the same time you are plugged in.
โAug-10-2014 07:59 AM
โAug-10-2014 06:55 AM
โAug-10-2014 06:10 AM
โAug-09-2014 09:11 PM
โAug-09-2014 08:49 PM
westend wrote:
This 15 amp Xantrex transfer switch would be perfect for your application.
โAug-09-2014 08:42 PM
BFL13 wrote:
"I don't have a genset, don't dry camp, and I'm only interested in using the inverter to power the refrigerator."
Lost me there. If you are always on shore power, why have an inverter at all? (except for that television re-boot thing some have)
โAug-09-2014 06:41 PM
โAug-09-2014 06:27 PM
โAug-09-2014 05:59 PM
โAug-09-2014 10:37 AM
DiskDoctr wrote:
Why not use a dbl sw/dbl throw 120v relay? The poles would be on the inverter side normally, and the 120v from any shore powered circuit would switch the poles to the shore power side.
Fridge would then run on inverter power and automatically switch to shore power when it was available, then back to inverter when shore power was removed.
