Aug-06-2014 06:32 PM
Aug-11-2014 02:14 PM
Bobbo wrote:
What I should have done was remove the GFCI outlet and replace it with a non-GFCI single 15 amp outlet. That way, there would be no risk of plugging anything else in there.
Aug-10-2014 07:55 PM
Aug-10-2014 04:59 PM
Bobbo wrote:
You are quite welcome.
As far as replacing a perfectly good electric element, I once replaced a full size upright deep freeze because the GFCI outlet it was plugged into went bad. Now THAT was an expensive lesson. The new deep freeze had the exact same failures as the old one, so I finally checked the outlet.
Aug-07-2014 08:35 AM
Aug-07-2014 04:24 AM
Aug-06-2014 06:44 PM
Aug-06-2014 06:41 PM
