โJul-03-2018 07:46 PM
โJul-04-2018 01:34 PM
wopachop wrote:
Got to the trailer and started the genny its been over a month.
Then plugged into shore power with an amp reader because i was curious if it would switch over.
Started the A/C and let it run for awhile.
Then turned off the genny with both A/Cs cranked full blast.
Only hooked up to 15amp.
Ran and killed the front bedroom manual hand dial.
Then turned the main room thermostat to off.
What damage can that cause to the electrical switch and the air conditioner?
โJul-04-2018 01:03 PM
โJul-04-2018 12:37 PM
โJul-04-2018 12:15 PM
MrWizard wrote:
Sam
When you move it, manual transfer, you are unplugging it
You disconnect either by manual switch or by physically moving some cord plug
Doxiemom
I think you mean you have an auto start for the genny
It's not the converter, it does sense battery voltage and start the genny when the battery is low, so the converter can charge them
โJul-04-2018 11:42 AM
โJul-04-2018 11:34 AM
wopachop wrote:
I can barely run off a 15 amp breaker either. Temporarily hooked the 14 gauge wire to a spare 20amp breaker. The garage outlet im using is about 30 feet from the panel. From there its a 50' 10 gauge electrical cord. Need to install a 30 or 50 amp setup at some point if im going to be doing the shore power thing during the summer temps.
โJul-04-2018 11:23 AM
โJul-04-2018 10:47 AM
โJul-04-2018 08:25 AM
โJul-04-2018 06:11 AM
MrWizard wrote:
never start the genny when plugged into shore power
never plug in to shore power while the genny is running
โJul-04-2018 06:07 AM
โJul-04-2018 04:22 AM
โJul-03-2018 10:30 PM
โJul-03-2018 10:07 PM
โJul-03-2018 10:00 PM
