switching to dual propane
waynefi
My new trailer came with a single propane bottle setup. I am planning to switch to dual bottles. Is there anything hard about that?
I think I need a new rack, a switchover valve, and a new cover. Anything else?
Are some switchover valves also regulators, or do I need to keep the one I have?
rPod 195
formerly Rockwood MiniLite 1809S
Tacoma V6
19 REPLIES 19
Tvov
Do you actually use a lot of propane? Just curious. My TT has two 30lb tanks, and we've never emptied one of them in one season. But... we only go out usually a couple weekends in the fall, when we mostly use the heater in the TT which gobbles propane.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
bucky
You'll also need a double holder, a rod, and a large wingnut to secure the new load. Maybe a 30 or 40 pounder single would be easier if height isn't an issue?
Puma 30RKSS
2_many_2
time2roll wrote:
x2 for Cavagna. New pigtails should be ordered too.
X3 for Cavagna, X2 for new pigtails
time2roll
Bobbo
This is the switchover valve that I recommend. It is also a regulator, so you don't need your current one. Other than that, you about have it covered.
Cavagna Kosan 924N RV Auto Changeover Regulator w/RV 'L' Bracket.
Bobbo and Lin
