tank heaters
64thunderbolt
My brother has a Cardinal 5th wheel travel trailer with arctic pkg. It has 2 grey tanks. Does 1 switch control both grey tanks? The switches are not labeled. Thanks to anyone that knows.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
4 REPLIES 4
64thunderbolt
Thanks Old-Biscuit. That was what I was thinking but wasn't 100% sure.
Glen
Truma tankless WH
2011 RZR 900xp
Old-Biscuit
1 switch for fresh
1 switch for black
1 switch for the 2 grey
64thunderbolt
he has 4 tanks total. fresh, black & 2 grey with 3 switches. Can't check it now. He is here in Az escaping the winter & his trailer is in storage in Ind. Thanks for the reply.
Glen
Truma tankless WH
2011 RZR 900xp
Old-Biscuit
Therein lays the problem......depends on what was installed.
Some of the 'arctic pkg' consisted of heat pads on fresh tank and all waste tanks.
1 switch controlled fresh and 1 switch controlled all on waste
(fresh tank pad used blue& white or black & white wires on switch-----waste tank pads used grey, brown or green wires on switch)
ALL pads the same and pull roughly 7A/each.
Thermostat controlled.....which switches them on at roughly 40*F and off at 60*F
If only 1 switch then it is for pads on waste tanks
