Therein lays the problem......depends on what was installed.
Some of the 'arctic pkg' consisted of heat pads on fresh tank and all waste tanks.
1 switch controlled fresh and 1 switch controlled all on waste
(fresh tank pad used blue& white or black & white wires on switch-----waste tank pads used grey, brown or green wires on switch)
ALL pads the same and pull roughly 7A/each.
Thermostat controlled.....which switches them on at roughly 40*F and off at 60*F
If only 1 switch then it is for pads on waste tanks
