May-05-2019 07:40 PM
Oct-30-2021 11:24 AM
myredracer wrote:cavie wrote:Agreed! Been retired too long and this stuff gives me a headache now. 😞
Ease up guys. Let's get back to electric for newbies 101. Save the electric engineering 2.0 for another forum. :):)
May-09-2019 02:21 PM
myredracer wrote:
But the 80% rule doesn't apply to plug-in loads. That would be like saying you can't plug a 1500 watt portable heater into a 15 amp receptacle because it draws more than 80% of 15 amps (12.5 amps). DW has a blow dryer that is rated 1875 watts (15.6 amps) and same thing there.
May-09-2019 01:33 PM
May-09-2019 01:32 PM
May-09-2019 01:28 PM
May-09-2019 01:24 PM
myredracer wrote:CA Traveler wrote:I understand what you are trying to say. But the 80% rule doesn't apply to plug-in loads. That would be like saying you can't plug a 1500 watt portable heater into a 15 amp receptacle because it draws more than 80% of 15 amps (12.5 amps). DW has a blow dryer that is rated 1875 watts (15.6 amps) and same thing there. (Interestingly, like portable heaters also, only has a 16 gauge cord.) There's other examples where plug-in loads exceeds 80% of a breaker on a circuit being plugged into. You can also have multiple receptacles on a circuit and easily exceed the 80% rule.
Keeping it simple just follow the NEC rule of 80% continuous load. I doubt any RV pedestal or RV panel is rated for 100% continuous load.
In this non simple article there is a lot more information. CLICK
If you can't or shouldn't exceed 24 amps on a 30 amp pedestal, why does the NEC require a 30 amp load allowance per pedestal? Why doesn't a pedestal say you shouldn't exceed 24 amps or an RV have a sticker on the power inlet saying the same? There is simply nothing in art. 551 that requires an RV to be considered as a continuous load.
RV pedestals have to meet UL standard 231 and molded case breakers, UL 489. I think you'll find that you have to look at a UL standard for a piece of equipment as whole, not individual components in it. I haven't looked for a copy of UL 231 and don't know what the details are in it.
A bit of a head scratcher question and no immediate answers pop up on google. IMHO, it boils down to RV and RV park rules in art. 551 and the fact that RVs are plug-in loads, not hardwired like in a building.
May-09-2019 01:20 PM
May-09-2019 01:17 PM
DFord wrote:
My experience over the many years I've been RVing has taught me drawing over 25 amps on a sustained basis (like when the a/c is trying to keep up during the heat of the day or space heaters on a cool night) will always ruin a cord plug. The connection points just aren't good enough to carry that load continuously. As proof, I submit the many 30 amp sockets you'll find in every park I've ever stayed at. They don't get burned up that way because they're carrying more than 30 amps because the breaker prevents that from happening.
May-09-2019 10:50 AM
May-09-2019 10:04 AM
May-09-2019 09:15 AM
CA Traveler wrote:With risk of over-complicating things and making it too long:myredracer wrote:It's an NEC recommendation.CA Traveler wrote:Where does that come from? Except for the condition of the receptacle in a pedestal and your shore power plug, you should be able to draw 30 amps continuously.
Plus the maximum recommended sustained load is 80%. ie 24A for 30A power.
May-09-2019 09:14 AM
