turbo brake vs PAC brake
bass_n_bob
is the turbo brake the same as a PAC brake or an engine brake or Jake brake???
THX
8 REPLIES 8
hypoxia
VGT
I have towed with a Ford F350 with VGT, very effective. Exhaust brake should be similar but I think slightly more effective. Engine brake AKA Jake brake is the most effective IMHO.
Jim
2007 Monaco Signature Noble III ISX 600HP
eHoefler
MEXICOWANDERER wrote:
Good question ๐Ÿ™‚
I have the Jacobs Engine Exhaust Brake with my Cummins 400. It has a 2-4-6 cylinders selector switch with clutch and throttle switches.
You have an engine compression brake, not an exhaust brake. Yours cracks open the exhaust valves right at cylinder ignition, cuasing no power stroke. The 2-4-6 settings is how many cylinders being used for braking. Compression brakes are far more affective than exhaust brakes.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
eHoefler
deleted
Old-Biscuit
My 2007 Dodge Ram with 5.9L has an Exhaust Brake.....installed in exhaust pipe after the turbo. Large 4" butterfly valve that closes and creates backpressure. Has a 2" butterfly vlave that controls amount of backpressure
2008 Dodge Ram with Cummins 6.7L has a 'turbo brake'......variable vanes in turbo that can change positions and create backpressure
Cummins also has 'Engine Brake' that is controls engine valve train....opens exhaust valves after compression stroke. Known as Jake Brake and makes that familiar rap-rap-rap noise you hear when semi truck uses it
PACBrake makes both Exhaust and Engine Brakes
coolbreeze01
This may help: http://www.ehow.com/about_6495304_exhaust-brake-vs_-jake-brake.html
PacBrake builds exhaust and engine brakes: http://pacbrake.com/supplemental-brakes/
2014 Sandsport 26FBSL
Ivylog
There are two types of exhaust brakes. One is a butterfly valve after the turbo that closes to create back pressure on the engine... much like the butterfly in the intake of a gas engine, just at the other end. Around 2006-7 variable vane turbos were able to create back pressure... not sure as much as a butterfly valve/Pac brake.
Upgraded with a 08 HR Navigator 45โ€™...
gkainz
The PAC brake i had on my '97 Dodge CTD was an exhaust brake. I miss having an exhaust brake enough the '07 Dodge CTD is getting one, too.
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
MEXICOWANDERER
Good question ๐Ÿ™‚
