Unequal Height Piano Hinge.
MEXICOWANDERER
I can't find them because I don't know the proper name for them.
A quarter-inch thick square of transparent polycarbonate
To read gauges, switches, and gauges beneath.
The Lexan hinges to a much larger surface lid read above.
NO clean edges on the box to have a 90-degree natural surface, the Lexan has to lay flat and open with a hinge
Got ideas?
Thanks.
3 REPLIES 3
opnspaces
Navigator II
Navigator II
Maybe it's a flush mount piano hinge.
Big_Katuna
Search on Amazon for offset hinge or offset piano hinge.
Not. Sure if thatโ€™s what your looking for. I looked on Rockler.com and didnโ€™t see as many as Amazon had.
My Kharma ran over my Dogma.
C_Schomer
I think they're called offset hinges but I've never seen offset piano hinges. i used to put the offset that I wanted into piano hinges with a sheet metal brake. Craig
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WILL ROGERS NEVER MET JOE BIDEN!
