Using 1 Battery only
fourthclassC
Howdy Folks. No dry camping planned this summer. My new rig has room and wiring for 2 batteries. Looking to save some $. Will anything bad happen if I just use one battery? (besides shorter amount of 12v ) Thank you
11 REPLIES 11
fourthclassC
OP Here - My bad. Should have clarified. Planning to run 1 coach battery instead of 2. Engine/Start battery in place. Class C. 2003 Winnebago Mini 24' V10. Planning to remove the short cables that allowed for 2 coach batteries.
tenbear
Just re-read your OP. If you mean your Class C is wired for 2 coach batteries, it will be fine with only one coach battery.
However, if you mean it is wired for one coach battery and one chassis battery, 2 batteries, you probably need them both.
2010 Subaru Impreza Sedan
Dave_H_M
RJ I don't quite understand your post.
I been running with one batt for years. The Ford has an isolator relay but i pull the plug at night to make sure all is well with the TV batt in the morning, :h
RJsfishin
Yes ! After watching tv 1/2 the nite, and your big block won't quite crank over in the morning after you were unexpectedly forced to make a stay at WM, then it'll be a slight problem.
Oh, this is not a MH ?? Kinda hard to know that.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
ScottG
westend wrote:
Nope.
I do like a succinct and accurate answer.
tenbear
Make sure that the unused connectors are well insulated so they won't cause any shorts.
MEXICOWANDERER
The way I used to save money was not leaving my wallet on the bed while taking a shower.
Gr8life
"Will anything bad happen if I just use one battery?"
Only if you opt for a six volt battery.
DrewE
No problems at all. If you find you need more capacity and/or less cash, you can always add a second 12V battery at a later time.
pianotuna
Nomad III
Nomad III
Having extra capacity really only matters if you are boondocking.
Regards, Don
westend
Nope.
'03 F-250 4x4 CC
