โApr-27-2019 07:48 AM
โMar-16-2020 07:19 AM
โApr-28-2019 12:01 AM
B.O. Plenty wrote:
See these posts every spring. Big temperature swings cause expansion/contraction of floor and floor coverings. Because they are different materials they move at different rates. Floor covering gets stretched, is brittle from the cold and cracks. They are not glued down. Glue won't hold with these big changes in temp. Easy solution. I've done several this way.
Cut around perimeter of old floor and lift it out to use as a pattern. I usually cut it across under the bathroom door and make a splice there covered with a strip. Lift the metal trim strip under the entry door and slip the new under it. Place the new sheet down after you have cut it to size using the sheet as a pattern. Hold it down around the edges with quarter round. Open beer.
B.O.
โApr-27-2019 11:12 PM
Harvard wrote:cullivoe wrote:
Over a very cold winter, the vinyl flooring in my โ07 Surveyor cracked almost all the way across right where my heat register is in the floor. Has this happened to anyone else? How did you fix it, and with that product?
During the winter, was this TT parked on 3 points (wheels and tongue jack ONLY) or was it also sitting on corner blocks?
My theory is that there will be no cold weather damage to the flooring if it is parked on 3 points over winter.
โApr-27-2019 07:41 PM
โApr-27-2019 05:37 PM
โApr-27-2019 02:50 PM
โApr-27-2019 01:36 PM
โApr-27-2019 12:28 PM
cullivoe wrote:
It was just sitting on wheels and tongue jack. No corner blocks
โApr-27-2019 11:00 AM
โApr-27-2019 09:12 AM
โApr-27-2019 08:35 AM
โApr-27-2019 08:33 AM
โApr-27-2019 08:23 AM
โApr-27-2019 08:12 AM
