โMar-17-2021 08:45 AM
โMar-18-2021 07:09 PM
Itinerant1 wrote:
Note that most of the bms's are not shutting down to low pack voltage but most likely to low cell voltage. The drop in manufacturers wouldn't want the packs eatting their own cells.
That is why it's best if possible to have a user adjustable inverter for low shutoff than have the battery use it last hail mary shutdown event.
โMar-18-2021 06:30 PM
โMar-18-2021 06:27 PM
time2roll wrote:Starting voltage 52.2. A/C on, drop to 51.4. After 3 minutes, 51.0. Recovered in 2 minutes to 52.2
Yes wait 'till sundown for the test.
โMar-18-2021 06:12 PM
โMar-18-2021 06:07 PM
โMar-18-2021 06:03 PM
โMar-18-2021 05:51 PM
โMar-18-2021 05:23 PM
โMar-18-2021 04:37 PM
โMar-18-2021 03:48 PM
โMar-18-2021 03:45 PM
time2roll wrote:Sure will, although I usually do that with the solar attached. I assume you mean with no charging attached....
Maybe 2oldman can share how much voltage bounce back is seen after running the air conditioner or microwave.
โMar-18-2021 02:41 PM
โMar-18-2021 01:36 PM
โMar-18-2021 01:12 PM
