โOct-29-2020 08:54 AM
โOct-30-2020 07:28 AM
Jetstreamer wrote:dougrainer wrote:
If you blow out, why do you not blow out the Washer also?????? What you do is, install a 1/2 gallon of antifreeze in the washer, set the water temp to Warm/Cold. Then when blowing out start a wash cycle. You will hear the 2 water valves blow air after the lines are purged and when the dump cycle activates, the antifreeze will go thru the drain pump. A lot easier. Doug
Thanks Doug Iโll consider that. I was just following manufacturers instructions.
โOct-30-2020 07:06 AM
โOct-30-2020 05:59 AM
โOct-29-2020 10:27 AM
โOct-29-2020 09:47 AM
