Water heater issue
Mbiallas
I am having an intermittent issue with my water heater and need advice. It's an Atwood propane only model with a 10 gallon capacity. The issue is that sometimes it will light right away like it's supposed to and run fine. Other times I have to go put there, light a stick on fire, shove it in the hole and run inside to turn the switch back on as it just won't light on its own (but the gas is definitely flowing) . Then sometimes it will fire up - nice pun huh? - for 10 seconds or so then quit and try to turn itself right back on. Usually when that happens the ignitor won't start it up and I have to do the stick trick again. Any ideas to help me track this little goblin down?
4 REPLIES 4
RJsfishin
Quote
- or quiet and smooth just right air
A quiet and smooth flame on a w. heater or fridge is never correct !
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
maillemaker
Is the ignitor firing (clicking) when it doesn't start? Have you tried cleaning the electrodes?
1990 Winnebago Warrior. "She may not look like much but she's got it where it counts!"
Mbiallas
It's not always 3 times. Sometimes just once. The flame seems fine to me. It's not overly noisy and seems to burn cleanly.
SDcampowneroper
Does it go the 3 tries before locking out? Is the flame loud like a jet- indicates too much air- or quiet and smooth just right air. Are you seeing any soot - not enough air.
Altitude is another factor
Are you hearing the ignitor clicking to light?
