โNov-25-2014 06:12 AM
โNov-25-2014 10:03 AM
Chris Bryant wrote:Star Gazer wrote:
He certainly did not bring up the fact that a contractor had drilled a hole in a tank a few weeks earlier and got water in the tank. When I mentioned that he said it was taken care of and had nothing to do with my situation.
My friendly tow truck driver said they got a few tows from that ๐
Why didn't you mention this in the first post?
โNov-25-2014 10:02 AM
โNov-25-2014 09:58 AM
โNov-25-2014 09:50 AM
โNov-25-2014 09:41 AM
โNov-25-2014 08:59 AM
โNov-25-2014 08:32 AM
โNov-25-2014 08:10 AM
They said the monitoring system showed no water in their system. Said they pumped 4000 gals out of that tank on Sunday and no one else reported a problem.Have you ever known a business to admit to prior complaints? A Google search might turn something up.
โNov-25-2014 08:00 AM
RJsfishin wrote:
Maybe not so sure about the whole thing ?? 2 gallons of water in 19 gallons of fuel ? A bit much to believe ??
โNov-25-2014 07:51 AM
โNov-25-2014 07:49 AM
โNov-25-2014 07:28 AM
Star Gazer wrote:
So they said if I had bad fuel I would have not even been able to drive off the lot even. However I had half a tank of good stuff, plus what was already in the fuel system. The gal jug showed that it holds about that so I know I had at least that much clean fuel. Then it probably took a few minutes for the contaminated fuel to mix with the good stuff too, and the water to sink, fill up my seperator, and stall me out? So driving 25 miles seems likely? I am only guessing as I am not a mechanic.
โNov-25-2014 06:46 AM
โNov-25-2014 06:44 AM
