Glad to hear your problem has been resolved.
FWIW; the 'pressure' was exactly the same. What worsened was the flow rate or gpm (gallons per minute). Pressure is measured with no fixtures running, (aka static pressure) in pounds. Your pressure gauge will tell you if you have a pressure problem. Flow rate is measured in gallons per minute. If the pressure remains normal, the loss of flow rate is indicative of a blockage or partial blockage as advised. Loss of pressure would be a pump problem if using your tanks, or outside the rig if hooked to city water.
Thus is is wise to check the pressure before checking for a blockage.
2015 Starcraft Launch 24RLS
2014 Ram 2500 diesel 4x4
Guarded by 2 Jack Russells
