Water pressure .
fordman57
Low water pressure kitchen sink. Replaced faucet still low ?
8 REPLIES 8
agesilaus
Second Chance wrote:
agesilaus wrote:
He said he already replaced the faucet
But he didn't say if he replaced it with another RV faucet (which will probably have a flow restrictor in it) or a residential faucet.
Rob
That's true
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
Second_Chance
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
agesilaus
Superbumper
Second_Chance
It may not be a pressure issue. Many RV kitchen faucets have flow restrictors that limit the flow rate. Some can be removed - some can't. If this is the issue, replacement with a residential faucet should fix it.
Rob
U.S. Army retired
Matt_Colie
If the galley tap is a modern residential version of anything with a single lever control, it may be plugged up with scale from the water heater. To clear this, you may have to figure out how to take it apart and find where the internal screen is so you can get the little ball of white scale out of it.
I have to do this with ours kind of regularly.
Why doesn't this happen at home? Because that water heater is bigger and the scale can collect in the bottom.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
wa8yxm
In one park I was at I had good flow from the park on a flow observation (no hose connected) but when I hooked to the RV nothign.. Turns out someone left a spigot open and the pump could not keep up.
Low flow at a SINGLE faucet indicates either a clogged faucet strainer (Replaced so we know that's not it) or a pinched line
Low flow at ALL faucets is indicitive of an RV Pressure Regulator of the 3/4" Cylinder type (Junk) Get a Valterra Adjustable and set it to 50 PSI give or take a bit or a Watts or Zurin 1/2 inch or larger in-ine with proper hose adapters.
rk911
was the pressure bad at every faucet? if you're using one of. those cheap screw on water pressure regulators know that they are easily plugged up. if you have one remove it and see if that restores pressure?
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
agesilaus
Then it's not the faucet. Generally you can just clean the wire mesh filter on the end of the spout to restore flow. Are you sure the water pressure into the RV is good? A kinked line, or a plugged water filter are other possibilities. Are you using the water pump?
Superbumper
