โDec-22-2015 10:04 AM
โDec-23-2015 03:50 AM
โDec-23-2015 03:15 AM
JimBollman wrote:
100LE AvGas, no additives needed, I drain the carb after use and put the generator away till I need it again. I have left it unused for 6+ months and the only problem is you have to slow pull the starter rope a dozen or so times to prime everything before you do a couple of serious pulls to start it. Gas is not cheap but I don't use that much. I keep about 15 gallons on hand and run it in my other small engines and replenish as needed. Shelf life on Av gas is 3+ years according to the manager of a small airport I use to buy from.
โDec-22-2015 06:12 PM
โDec-22-2015 05:00 PM
โDec-22-2015 04:27 PM
โDec-22-2015 12:04 PM
โDec-22-2015 11:40 AM
boogie_4wheel wrote:
Drain the bowl. The gas will evaporate over time anyways, so if you leave it full at shutdown, a majority of it will be gone come next month.
โDec-22-2015 11:19 AM
โDec-22-2015 10:47 AM
โDec-22-2015 10:37 AM
โDec-22-2015 10:28 AM
TomG2 wrote:
I have been shutting off the fuel valve and letting it run dry.
โDec-22-2015 10:18 AM
