What are the good quality bearings for a TT?
myredracer
Timken or SKF are as good as they get? A frame shop told me few years the name of a good one made in Japan but can't remember the name.
This is the first time for me to be ordering bearings and seals for our TT. Do I just need the part number off our axles and go onto the bearing and/or the Alko's website? Do they come as a kit with nut, cotter pin etc?
A bit unclear on the info. on our axle sticker. Says axles are 4400 lbs and are T52D-H9. Alko's website says T52 axles are rated 5K lbs?
55 REPLIES 55
ktmrfs
axle should also have a tag listing the axle weight rating and often a stamp as well.
Alko 5200lb axles normally have 12" brakes with 6 lug wheels, 4400lb Alko have 10" brakes and 5 or 6 lug wheels.
Also std ratings are 4400lbs and 5200lbs not 5,000.
the 4400 and 5200 lb axles use completely different bearings.
2011 Keystone Outback 295RE
brulaz
My 5200# Al-Ko axles have a label on them that says "Plant 52 (La Grande)" and under that the part number starts with "T52D ULFL" then lots of numbers. At the bottom of the label it clearly says "Capacity 5200#"
My guess is that T52D refers to the plant number, not the weight rating.
When you replace the bearing, don't you replace the race as well?
I've re-greased bearings and replaced the seals, but never replaced the bearing and races. Getting the races in/out properly sounds tricky to me.
I see etrailer.com and Google/utube have lots of info on it.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
edbehnke
maintenance is much more important, most bearing in axles are probably made in china so don't lose any sleep over what bearing you buy. etrailer.com can help you too.
eddie and sandie
3402 Montana 2013
Ford F350 2015
ernie1
My SKF bearings were made in Japan.
midnightsadie
I live in canton ohio home of timken roller bearing , made in the U.S.A
time2roll
Also please provide a link that shows Timken trailers bearings are made in the USA.
Google pretty much says China.
CKNSLS
TXiceman wrote:
smkettner wrote:
Set-up and maintenance is far away more important than brand.
Not true. Junk Chinese bearings are junk.
Ken
Please elaborate on how thousands of trailers are on the road with Chinese bearings and they are not sitting on the side of the road smoking from overheating. Many in fact, probably do not get even yearly inspections.
Please do tell us how they are junk?
BTW-do you shop at Walmart-Have a smart phone? How about a flat screen T.V.? They are all Chinese junk. Must have the same performance as you claim the bearings have.
TXiceman
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
time2roll
myredracer
Lynnmor wrote:
One place for Timken bearing kits:
bearings
Thanks Lynn!
Lynnmor
bearings
