โOct-26-2021 12:17 PM
โOct-27-2021 04:24 PM
โOct-27-2021 03:32 PM
jaycocreek wrote:
I bought a Enjoybot 100ah lifepo4 battery when they were $349..The resting voltage after 24hrs was 13.30 without a load..Back and forth with the seller was interesting,so I decided to do a capacity test on it from a full 14.47V and I quit at 11.89V under a load and 12.0 resting for a few minutes foran even 100 amp hours...
I am assuming that a 13.30 resting 24hr voltage without a load is okay as it appears to have the advertised 100 amp hours plus a couple...All opinions welcome...
jaycocreek wrote:Available, usable ah is the most important consideration IMO. It appears your battery produced its rated 100ah, so all appears well. Sure, it would be nice if the voltages aligned perfectly with whatever lifepo4 SOC chart you choose to follow, but it's certainly not necessary from an operational perspective.
Some of this stuff is hard to understand and can consume one to try and understand it but I think different cells and make up give different results and in the end what I want is the amp hours I payed for and a fully functional battery..Battleborn uses cylindrical cells just like the new lifepo4 solar generators like Bluetti while others use prismatic which seems to be the most used in lifepo4 rv batteries...
While this battery resting is on the low side,it produces the full 100ah plus some,so I'm pleased with the purchase....One article says 3.30 resting is 90% another says it's still 100% and normal...Laffin....So if 3.30 resting gives me over 100ah,it must be full..right...:B
โOct-27-2021 03:03 PM
โOct-27-2021 12:41 PM
โOct-27-2021 12:23 PM
otrfun wrote:
We've done a number of deep discharge SOC tests with our 200ah lifepo4.
โOct-27-2021 11:54 AM
โOct-27-2021 09:14 AM
โOct-26-2021 02:21 PM
โOct-26-2021 01:45 PM
โOct-26-2021 01:26 PM
โOct-26-2021 01:23 PM
โOct-26-2021 12:42 PM
